My software and hardware updating
Respected Wilson Coronel
Software Updates:
1. In order to update your software just visit to https://www.google.com/?gws_rd=ssl and in search type model number and search for latest downloads.
2. Or download any driver updater software as Device Doctor Version 2.0 or Driver Max or Slim Drivers or any other you want, scan and update.
3. Put your windows setting to auto update and system will do the rest.
Hardware Updates:
Visit again to any web searching site as www.google.com and search for the new hardware in the market and change it with your old one.
Upgrading hardware is either upgrading the device’s firmware or the driver installed in Windows. When upgrading a device’s firmware, this is usually done to improve the device’s functions and fix any bug issues associated from the previous or original firmware.
The upgrade file can normally be acquired from the device’s official website so you better visit its website to know if there is an upgrade available for the model of the device.
In a firmware upgrade, the upgrade file is actually installed right within the device and not on Windows. The program that actually runs the device and is built-in the hardware is the one upgraded. When upgrading software, you can usually do it right from the program.
Open the program then click on the Help menu then check if you will be able to see an upgrade link or update button from the menu. Just click on that button to start upgrading the application. You can also visit the program’s official website to find out if there is already an available update for your version.
Notifications
