Aron Morgan
Posted on - 09/26/2012
My SQL server has encountered a problem with metapad. The screenshot of the message is as under.
I tried to solve the problem but failed.
Please help me.Â
metapad
The process cannot access the file because it is being used by another process.
Hello Aron,
To resolve that issue, you will need to check
Hi Aron,
I have faced a similar problem some time back, all  this message states that there is process running on which is using the file. In order to remove this error, you have to go to Task manager -> Processes tab-> Select the process-> End the process and also restart its service. This will solve the problem.
