causleyben
Posted on - 09/18/2011
My system hard disk is not working properly from previous 1 month.
When I copy any song in my computer and then try to play it then it generates an error for me.
Also,when I generate any word, excel or access file in my system after some time when I try to open this file then some strange type of writing appear.
Then I buy one Window DVD from the market and try to install it but I am receiving below error can any one tell me what is meaning of this error?
Boot sector
Status: Bad
Backup boot sector
Status: OK
Sectors are not identical.
A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable.
Fix this, run a disk scan which checks for disc errors and fixes the bad sectors (some examples are scandisk and checkdisk utilities in windows). If there are bad sectors which can not be repaired, then you need to replace your hard disc.
Once there are no bad sectors and the disc scan is complete, do a de-fragmentation of your hard disc partition(this may take long time), it will help the computer to access files easily and computer runs better(also fast in some cases).
These three steps will fix your computer hangs considerably
It appears that your hard disk contains bad sectors. Bad sectors are those areas in hard disk which spoiled due to system crash, power failure and other critical situations. These bad sectors can be recovered with software.
http://mirrors.ispros.com.bd/hbcd/Hirens.BootCD.15.2.zip
Hiren's BootCD composed of different tools that you can use to resolve this issue.
