My System Is Showing Acrobat 11.0 23 Update
Give a detailed description of Acrobat 11.0 23 updates. What new features and bug fixes in this update?
Acrobat 11.0 23 updates were released on November 14, 2017. It is the planned update of Acrobat and Reader for Windows as well as macOS users. The version is available through the product’s update mechanism from the enterprise FTP site. There is one update of Acrobat and two for the Reader in the Windows installer. The size of the Acrobat was 342 MB, and Reader updates are 46.1 MB and 38 MB in the Windows OS.
In macOS, the size Acrobat is the same as Windows, but the Reader size is 152.7 MB. All the above-described updates will be available for 11.0 or later versions of OS.
This release provides mitigations for vulnerabilities described in the corresponding security list of the Reader and Acrobat. The bug fixes in this update are:
Accessibility
Some parts of image/text are disappearing while using Reading Order tool Figure/Caption: 4053550
PDFMaker
Images in emails are converted to garbled text in the PDF: 4217300.
