Hi friends,
I want to know why my tethering feature is not working in my new Galaxy Core 2 smartphone. I purchased this smartphone Galaxy Core 2 two weeks ago and did not used tethering network till now in this mobile but what I noticed today is though I made all the settings properly its tethering network is not working.
My tethering hotspot is not working on Galaxy Core 2?
Hi Neal, more often than not, if this is the first time you are going to use the mobile device, chances are you just need to double check your configuration. If you already followed up the steps like going to your Settings then tap the More option, then select Tethering & Portable Hotspots and lastly USB Tethering then try the following if that still won't make your phone act as a modem. Check your WiFi if it is on, try to disable it, since it will conflict with your mobile data. Also make sure your mobile data is enabled, otherwise you won't have access to the internet.
