gabmor
10 points
Posted on - 03/16/2012
I have thinkpad x100e. It was infected by win32.mabezat.B virus and I have cleaned it. And now if I turn it on, there will be error message:
'ERROR 0210: Stuck key 1c, press f1 to setup.
I have reinstalled the windows, but it didn't fix the problem.
My Thinkpad affected my viruses
Hello Gabmor.
The problem you describe is not related to any virus infection.
[ERROR 0210: Stuck key 1c, press f1 to setup] means exactly what it says – one of the keys is stuck. Based on the error code, the key that is stuck is "1c". Based on this keyboards scancode reference: http://www.win.tue.nl/~aeb/linux/kbd/scancodes-1.html, "1c" is the ENTER key.
Did you spill anything on your keyboard before this happened? I suggest you try removing the ENTER key and cleaning the contacts. Some cases of stuck keys can be as simple as dirt or a piece of lint or cotton stuck in the key slot. If you spilled something on the keyboard then you should dry it out with a hair dryer.
