My TinyUmbrella has encountered a problem
My TinyUmbrella has encountered a problem. I received an error message while using TinyUmbrella.
The screenshot of the error message is as under. It has failed to start TSS Service.
How can I become an administrator to run TinyUmbrella.
Have you any idea for the issue?
Please help.
Cannot Start TSS Service
DO NOT TRY RESTORING YOUR DEVICE!!!
TinyUmbrella MUST be run as an Administrator!
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #191475
Hi Adams Baker,
If it happens again do this: Run the task manager on your computer, and then click the processes tab, right click the all httpd.exe and select end process, there are more than one httpd.exe. Be careful not to choose other than that file. After that, restart tinyumbrella. Check this out: http://ww12.neuronaltraining.net
Answered By 10 points N/A #191476
If you want to solve that problem then you need to follow these steps:
1. Download firmware for your device.
2. Make sure your SHSH are saved by opening cydia, and looking at the top of the home screen and make sure that Tiny Umbrella is not running in the background.
