MY TOSHIBA LAPTOP DID NOT DISPLAY GAMES
 Hello my Toshiba laptop directX is stop working & also can not display 3D product.what is the solution?
If your Laptop has a 3D acceleration interface supported graphics card then I think I have a solution for you but if you don't have any device like that then I am afraid we have nothing to do but to buy a 3D supported Laptop.
If there is no problem with hardware then you may try following steps :
1. Install Direct X ( latest Version) *** its a simple process like other installation of Apps.
Just click next-next Finish!
2. Restart your computer & you may find your problem is solved. If you don't have the backup of Direct X installation file then you can download it from here
All Microsoft Windows operating systems already come with its own DirectX version and it’s already pre-installed. If by any chance your operating system’s DirectX suddenly doesn’t work, the best way to fix it, I guess, is to reinstall it. Although it can’t be uninstalled from the system, you can always download the appropriate version then run it to begin reinstalling the program. I’m not sure how DirectX would not work since you don’t normally access it like any other programs.
Since you select Windows 7 from the category of your inquiry then I guess you are using Microsoft Windows 7.
The best way to download the latest version of DirectX is to search for it in Microsoft’s website, Microsoft | Download Center | DirectX. Here’s a little history about the different versions of DirectX. DirectX 11 supports Windows 7 and Windows 8. If you are using Windows Vista and you want to install this version, you need to install an operating system update to enable you to install DirectX 11.
You can download the Windows Vista 32-bit update from Microsoft | Download Center | Update for Windows Vista (KB971512) and the 64-bit update from Microsoft | Download Center | Update for Windows Vista for x64-based Systems (KB971512). DirectX 10 supports Windows Vista, Windows 7, and Windows 8. DirectX 9 is the latest version applicable for Microsoft Windows XP and supports Windows XP, Windows Vista, Windows 7, and Windows 8.
Thanks a lot to all of you guys for your kind help. I was at a loss to see this problem and I also tried myself to alleviate this problem but all my efforts were in vain. All of your solutions were effective but Sharath, you have detected my problem accurately, which problems cause was not known to me before reading your comment. I also faced problem with DirectX.
I couldn’t install the proper version of DirectX because I didn’t know which version is compatible with my Windows Vista Ultimate. Now I have got my answer. DirectX 10 is the most suitable for my Windows Vista. I really love computer operating now. I love to visit this site because I'd gathered a lot of information and give me a courage to practice yourself in troubleshooting problems. Thanks very much, Sharath. I am very glad to be free from this annoying issue.
