My Toshiba optical disk drive service is not working
Hello Experts,
My toshiba optical disk drive is not working. I am having this kind of error " TODDSrv.exe not found". I need a solution for this as soon as possible. Please do advise me what to do.
Thank you.
Best Answer by Jack Hostler
Answered By 5 points N/A #156212
Hello Jaylonomarion
TODDSrv.exe is a backup service from Toshiba. It's located at "C:/Windows/System32". This is related to the driver of Toshiba Optical Drive. Since it's not found, that means driver of the optical drive is corrupted and you need to reinstall it. Just go to Toshiba's website and enter your model number to obtain the driver file for your optical drive. Check that whether the file TODDSrv.exe is present in C:/Windows/System32. If it is present, then you are good to go.
HAppy Computing 🙂
-Jack Hostler
Answered By 0 points N/A #156213
The possible solution to the problem you are encountering is given below.
1. Download Toddsrv.exe repair tool from a trusted website.
2. Save the file and install it on your system.
3. Most probably after starting the repair tool it will ask for Scan. Allow the scan.
4. When the scan is completed located the Repair all button and click on it.
This will fix the error you are facing.
