My video card is GEFORCE 8600 and it crashes everytime when I play NBA2k12 and Starcraft 2, and the only solution is to restart the PC. My OS is windows xp, my motherboard is ASUS P5K SE/EPU, I have1Gb memory, 260 hard disk (60 remaining)
Is there any problem with my specs or what?
Thanks
My video card freeze whenever I play 2k12
Hi, i think you need to upgrade your computer specifications, especially with your video card and if possible you need to add additional RAM for your computer because unfortunately your computer needed to be upgraded so that it will not freeze everytime you try to play NBA2K12 and Starcraft 2.
According to the game developer of NBA 2K 12 the system requirements for playing the game are, first we must know your CPU if your using Intel or AMD CPU, if your using Intel you should have Core 2 Duo E8300 2.83ghz while if your using AMD you should have Athlon II X2 255.About your GPU for Intel you can use Geforce 8800 GTS while for AMD GPU you can use Radeon HD 3800 series
.For RAM you should have at least 3 GB , your OS is good, on direct x you should installed the DX 9, and your free HD space should be 8.5 GB.
If you follow this system requirements i am pretty sure you will have no problem on your gaming and you will enjoy your time playing.
