Can you tell me what's the reason why my winamp play slow mpeg4 files? There are no problems with other movie files but during I play mpeg4 files to my computer, it takes a couple of time to load. What should I do? Should I clean cookies and cache? I'm running Windows 7 Starter.
My winamp play slow mpeg4 files
HI,
Dear you are using Winamp but Mpeg4 file is playing slow.
There are two basic reasons of this problem.
First is about your installed winamp package and second is about your MPEG4 file.
Check your software clearly that all plugins and codec relating to MPEG4 Media files are properly installed and working well?
Then check the Resolution of your MPEG4 File. When you will play a high definition (HD) file, the file will play slowly. Check both of these.
I hope this answer will help you a lot.
Regards
