My Windows 8 gets froze for no reason
I've just newly installed my Windows 8 upgraded from Windows 7 it runs smoothly without any problem. However, 4 hours after It gets froze so I force restart it, and it froze again in a few minutes, and I restart again and froze again. So I leave it overnight, and I turn it on this morning but this time it froze on start up. What would I do?
Best Answer by Franke Mary
Answered By 0 points N/A #143633
Hello James Belt,
First check the windows system requirements if your computer doesn't meet the requirements, it can happen
or that happened because your windows didn't install clearly check your ROM device, maybe there are some problems there, that cause the windows CD cannot copy all its components well maybe you can uninstall your windows 8, then try to re-install it.
Answered By 10 points N/A #196256
You should setup your pc again or Update Frozen Windows 8.
Five tips for dealing with a frozen Windows Set up.
1: Be patient.
2: Disable the floppy disk controller.
3: Check your memory voltage.
4: Try removing memory.
5: Try using an IDE or a USB DVD drive.
Generally, if the system is stuck [and you will know when it is], reboot the system. Generally, Windows will continue after where it got stuck.
[Check the logs to see where it coughed up a furball.]
Thanking you,
Franke Mary
