My Windows 98 Power Saving/Standby mode does not work.
There is much kind of things that can prevent this tool to work. Some are like any third party applications, screen savers of your windows or might be your APM driver is corrupt. There can be another cause also, that is any hardware may prevent power saving mode. So the solution part is huge first and foremost thing is you have to check that your power management is enabled. To check that go to start button> settings >control panel> power management. Turn off any screen saver; unplug any removable drive like pen drive. Update your power management driver; also check that the power saver is enable in the BIOS.
Hello User
Did you see any error message displayed when you try to standby, it would be greatly helpful if you can describe it. Do the following to resolve your issue
Hope this help
