My Windows Domain Account Keeps Locking Out Frequently?
I have two domain controllers and three member servers which are running on Windows Server 2003. All the other workstations connected to this Network are running on Windows XP. Those domain account keeps locking out frequently. Is there any problem with the domain computers or with the workstations.
Answered By 25 points N/A #157829
You can use the LockoutStatus.exe App to know exactly the origin of the problem. This app is of Account and Lockout management package. It will assist you to keep track on your lockouts and inform you about the origin and the destination of the same.
You can also try to use filter in Security log of domain controller if you are using ch account logon security policy and more details will also be obtained about the lockout
The event log can provide you with an error code which if understood can troubleshoot the problem, and also details about the Source IP address can be found to identify the computer that tried to log in is irrational.
