Recently, I got new SONY Vaio SVD13223CXB VAIO, Duo 13 Convertible Ultrabook with Windows 8 and I liked it so much.
Everything works fine, but wireless Internet connection is too damn slow. I thought it was because of the Internet or WiFi adapter itself. I am using Realtek RTL8188EE 802.11bgn Wi-Fi Adapter. On my laptops the same wireless connection is very fast and I am not sure why it is dead slow in my new laptop only. I have updated the drivers but no luck.
What is a possible cause of this problem? Please help me out here guys.
My wireless connection is very slow
Taking in consideration the fact that you already update the laptop's wireless drivers, i will proceed with debugging what could've happened to your wireless card.
I would imply that you should test other wireless connections to see if the problem persists. If the connection is still slow, then i would recommend in replacing your wireless card. If other laptops or computers behave normally while connecting to the wireless network, then it is safe to assume that a new wireless card for you laptop will be needed.
It might also be a problem with outside interference. Microwave ovens, 2 GHz cordless phones, and other wireless adapters connecting to your network will influence the connection speed. If this case is a problem, eliminate them by staying away from them or turning them off.
