My Xbox Throws 80151006 Error While Launching The Application
Write the detailed points on the 80151006 error? What is the cause of the error code, and explain the methods to overcome this error message?
Xbox error code named as 80151006 error occurs when trying to launch an application like Netflix or when trying to play a Bluray disk. 800151006 error code is accompanied by “Sorry, this profile can’t connect to Xbox LIVE on this console. To fix it, download it again” error message that encourages the user to restart the application again. Improper alternate MAC address, Xbox One server issue, System file corruption, Firmware-related issue are reasons for the occurrence of the error code. The methods to fix the error code are as follows:
Method 1:
Clearing the MAC address.
Step 1: Press the Xbox One button to open the guide menu. Now, navigate to the Settings icon and open it.
Step 2: Choose Network settings from the Settings tab.
Step 3: Now, move to the Advance Settings menu.
Step 3: Select the Alternate MAC address from the available options.
Step 4: Use the Clear option to clear the MAC address.
Restart the system and check for the error again.
Method 2:
Run the application in Offline Mode.
Method 3:
Perform a console factory Reset.
Step 1: Click on the Xbox icon and select the Settings menu.
Step 2: Select the System tab, and from the right-hand side, choose Console info & upgrades.
Step 3: Choose Reset console before clicking Reset & keep my games & apps from the option.
Wait for the process to complete, then restart the computer.
Notifications
