MySQL database with Desktop Applications
I'm a software developer who develops both desktop applications and web applications. My preferable database when developing desktop applications would be MS SQL Server. Sometimes I use Sybase SQL Anywhere and MS Access Database.
Recently I heard that MySQL can be used for desktop applications. I only use MySQL for web applications but if it's true that MySQL can be used in desktop environment as well that would be great I can connect both web and desktop applications to MySQL and interact with each other.
I'm using Visual Basic to develop desktop application while I'm using Netbeans for web applications. I'm very excited with the prospect of developing web and desktop applications connected to MySQL database. The prospects are endless and I just can't wait to apply it for the next project if it's true. Unfortunately I can't find the information I need while Googling.
I'm currently using Windows XP 32 bit SP3 with 2 GB RAM installed. Is there any additional steps needed to make MySQL database work with desktop applications? Or any additional files needed to be installed to make it work? I'm open to any ideas and suggestions guys. Looking forward to hearing from you all.
Thanks,
Stan
