redford
Posted on - 10/19/2011
Hello experts,
I have  troubled connecting to the database and  I am  facing this problem after I installed several software such as mail server and also after I enabled my IIS on my Windows 7 OS. I have done reinstalling IIS and as well as re installing my WAMP server but no luck at all. After that I installed it back, it displays an error  MySQL Error Code is 2013 while connecting to the Database.
What causes this error? Do I need to replace my server? MySQL version is 5.0.18. Or is this something to do with conflict in ports? I just don’t have the knowledge to overcome this problem.Â
I appreciate your help.
Thank you,
Redford
Jackman
MySQL Error Code 2013 on Connecting to the Database
First of all, check that your system has the minimum requirement for running MySQL server and these other domains that you have running in your system because if all the minimum system requirements are met, then there will be no errors. There should be at least 256MB available to be able to run it properly as it needs a lot of memory.
I hope you followed the steps properly, to fix the mail server on unlimited user's domain. Try creating independent host names for each domain to see if it will work well. Check that all the drivers are updated and working well. These are only a part of the problems in MySQL, that may cause errors. If all drives are working then the servers will all be well supported.
