peaks
Posted on - 04/04/2012
I really need help on the experts.
If ever you know what causes this error, please tell me right away.
What should I do to solve this particular error.
Thank you so much.
Error:
mysqld.exe has encountered a problem and needs to close.We are sorry for the inconvenience.If you were in the middle of something, the information you were working on might be lost. Please tell Microsoft about this problem.
We have created an error report that you can send to us.We will treat this report as confidential and anonymous.
To see what this error report contains,click here.
MySQL Error Message Display Help
It seems that your MySQL application crashed. Try restarting your computer and then try it again. If the application still failed to load on the next attempt, uninstall MySQL from your computer then check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks.
After checking your hard drive, install MySQL again. After the installation, open it and see what happens. If the application works, maybe it only encountered an error in the file system and corrupted its files.
But if the application still failed to load with the same error, check if the current version of MySQL on your computer is compatible with your operating system. It is possible that the cause of the problem is system incompatibility.
In this case, just replace the version with the one compatible with your system.
First thing to do is to check the compatibility of your MySQL version with the operating system you are using on the computer.
If it’s ok, then uninstall MySQL, thoroughly check your computer (perform a hardware diagnostic) and also use an antivirus program. Reinstall MySQL and everything should be ok now.
