MyTouch Q from T-Mobile ?
New MyTouch Q mobile from T-Mobiles? What is the cost of that T-Mobile. Can we buy this mobile online and what features does this mobile offer. Pros and cons of the mobile also?
Hello Maxine, I have read your query regarding the MyTouch Q Mobile. I have done some research about it and found out that it has the following features and specifications:
–      Android device with 3.5 inch touchscreen, QWERTY keyboard
–      Resolution: 320×480 pixels
–      Display: Light sensor/Proximity sensor
–      Camera: 5 megapixels (Auto focus)
–      USB 2.0 , Mass Storage Device, USB charging
–      Internet Browsing supports HTML and Flash
–      Single core, 1000 Mhz, Scorpion processor
–      512 MB RAM/2048MB ROM System memory
Its Pros include: Fast processor and fast mobile data support (4G)
Its Cons include: Bulky, Low pixel density sceen, no front-facing camera.
Its cost is around $80 in the market, but when you get it in a plan, it can be for as low as $49.99. Please refer to the link for inquiring for a plan.
The T-Mobile myTouch Q is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on October 2011 and released on November 2011. It measures 121 x 64 x 13 millimeters and weighs 160 grams. It uses mini-SIM card with QWERTY keyboard. It has TFT capacitive touchscreen display with 16M colors at 320 x 480 pixels screen resolution.
It runs on Android 2.3 Gingerbread powered by Qualcomm MSM8255 Snapdragon S2 chipset, 1.0 GHz Scorpion processor, and Adreno 205 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 2 GB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus featuring geo-tagging and can record video in 720p at 30 fps.
It doesn’t have a secondary camera. It has 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with DLNA, UMA, and hotspot support; Bluetooth 3.0 with A2DP and EDR support; GPS with A-GPS support; stereo FM radio with RDS support; and microUSB 2.0. It has built-in accelerometer and proximity sensors. The preinstalled web browser supports HTML with Adobe Flash support. It supports Java via Java MIDP emulator.
It runs on removable Li-Ion 1500 mAh battery with standby time up to 280 hours and talk time up to 3 hours 20 minutes. It is available in gray and violet colors.
