N73 battery low when calling problem.
Hello experts,
N73 battery low when calling problem. I have an n73 Nokia mobile phone for almost 1 year and I am having a problem with the battery performance. I just want to ask if you could give some suggestions regarding this matter.
Thank you.
Best Answer by Amanda Angel
Answered By 0 points N/A #188032
When we are continuously using Nokia mobile phone day by day the performance may degrade. You said that your mobile phone already used 1 years. So that naturally the performance are reduced. In Nokia devices battery warranty is 1 years. So you can buy a new battery if you want to get better performance.
Answered By 0 points N/A #188033
Hi Stephen,
Battery life has always been a problem for cell phone users. But there are several things you can do to lengthen the battery life of your cell phone.
First, you can reduce the number of open applications by making sure that you close them properly. You can check what applications are currently open or running in the background by holding down the menu button. Once you see the list of open applications, close those that you don’t use so they won’t eat up your battery life.
Another way is to make sure that you turn off WiFi, 3G or Bluetooth if you’re not using them. These three programs take a lot of battery life so make sure to turn them off. You can also use the Power Saver option in Nokia so it will turn off the backlight feature of your phone.
You can also use a program to manage the battery life of your computer. One application I found is BatteryLife. It monitors your battery life and will give you an estimate of your remaining standby and talk time so you’ll be able to manage your phone’s battery life better. Here’s the link for it BatteryLife.
 Hope this helps you Stephen.
Answered By 0 points N/A #188034
Hello Stephen Heris,
Maybe your Battery is the problem.
Your battery maybe over charged or its class is low.
Try buying a new battery for your phone. A high class battery.
So you won't encounter it again.
Hope this helped you!
