N8 say caller name Smartphone is not audible with Bluetooth
Friendz,
Say the caller name is absolutely fine when I did not connect to my Smartphone N8 with Bluetooth. But when I connect to Bluetooth the voice is barely audible.
Ringtone is very loud but voice is not like to audible with comfortable.
Please help someone.
Answered By 10 points N/A #162664
The problem you are facing is weird but I will try to help you but not sure what kind of format tones in N8.
Take any ringtone you like and open it on a computer with the help of any editing audio software.
I will suggest you audacity.
transfer to your phone and make your ringtone
In audacity reduce the audio volume and save it. Then transfer to your phone and make your ringtone or secondly put beep tone as your ringtone. It will let you hear caller name.
Hope your problem gets solved by this solution.
