HELLO !
I have some folders about 30 to 40 and each folder contains around 50 files. I used a USB device to transfer some files from my laptop to my P.C , after removing the USB device, in folders of my laptop a file name as MAIL is visible now and if I delete the file it comes back again so can you provide me a name of any antivirus which repairs the file ?
Name antivirus which repairs the file
HI Sanderford,
I m not sure whether this works for you or not to get your data back try this unhide your folders and files by reaching this go to folder and search options tab view check in show hidden folder and files and apply changes.Then  try to look files in your folders if it shows to you copy from there  second option is use Nero software to see all files in your folder. once your you'll get your data I recommend to format your pc then secure it with quick heal..
Thanks
