Name a high upload dedicated server and how to configure it ??
Can anyone kindly suggest that which company can provide "high upload dedicated server" and kindly mention the configuration process for most optimized performance?
GoDaddy is the best suggestion for you. It supplies “High Performance” and the rates are just fine. It’s highly recommended that use a PHP Accelerator for low load on “CPU”.
It provides some of the hosting selections from sharing a server among by the other customers and the charges are around $5 per month, to dedicated servers.
Hey,
Alternatively you can use Hostgator,
They have excellent support faculties and reasonable prices.
They also offer an easy way to set up your server, guiding you through the whole process,
Hostgator offers various optimization methods for your needs.
They can be easily accessed on the server management panel.
Hope that helps.
Notifications
