Name of manufacturer of boiler for Computer Drive
I heard from one of my friend about Horizontal Boiler for Computer Drive, Do any one know about manufacturer of boiler, which can be operated using computer through USB
Horizontal boiler is a water-tube boiler having a main bank of straight tubes lean toward the behind at an angle of 5 to 15° from the horizontal. I have searched through internet and i haven’t found any manufacturer that produces Horizontal Boiler that can control by computer USB port. Though I found USB controlled Coffee Boiler and fragmented burner.
Giving you links hope that might help you.
Hi Suzanne Lerson
I have some site that maybe should help to find those manufacturer's of Horizontal Boiler for Computer Drive that you've been looking for, hope this will be help,   http://www.architectmagazine.com/products/23-52-16-condensing-boilers.aspx.Â
and this site would be help for more informations; http://thesteamemporium.com/maets-gallery/computer-disk-vessel/horizontal-steam-boiler-a
feel free to reply for more questions.Â
Have a good day.
