Name Server Daemon (NSD and Hypertext Transfer Protocol (HTTP)
What is the function of Name Server Daemon (NSD) and how to analyze the Hypertext Transfer Protocol (HTTP) as task performed when there is an increase in the number of concurrent users? The data analysis will help us to determine the problem sites and assist them.
Answered By 0 points N/A #138232
The real function of the Name Server Daemon might be different from system to system since a lot of people use it for a lot of purposes but if you are using it with the HTML that you are talking about then there is only 1 use of it.
People who use Name Server Daemon require a certain pattern that they use to name their server so that it can be correctly synced with the rest of the world.
Sometimes people get problems while connecting to a website but using the Name Server Daemon they can easily connect it because it will automatically rename the server according to the visitor country or the IP or maybe the ISP if that is the case.
In this way, the website will not reject any user based on specific country or region that most people do and will allow traffic from all over the world.
