Name the top Antivirus for Mac
Please help me to find the best Antivirus software that will be free for Mac. My main motive is to prevent web spawned threats as I am using the Internet from my MacBook
Hi Miller,
I recommend you avast! antivirus solution for mac. It is highly recommended and praised by many users.
As you stated, it has free version. It should suit your requirements.
It includes security from web-spawned threats and such.
To download it, click this link and then downloaded, install it.
No need to configure it because standard configuration is good enough.
Hope this helps you.
Good day Miller
I`ve been using Avast antivirus for over 4 years and is very happy with its performance. You can download it from https://www.avast.com/free-mac-security It is for Mac and Windows compatible.
You can download it for free. This version I`ve been using without regrets. It keeps you updated every time you go on the internet, or stay on. The updates are not big if your data plan is not big.
Another free antivirus is Kaspersky also good. Updates easily without any hassles. You can download it from https://usa.kaspersky.com/
