Names Of Best CD DVD Burning Software For Windows
Which is the best CD DVD burning software for windows? Is there software that works for both Windows and Linux? What is the difference between CD and DVD?
Few of the best software that is available for free are ImgBurn, Nero, Infra Recorder, Roxio. The software that works on both Windows and Linux is Nero, ImgBurn.etc. The major difference between CD and DVD is the disc space that is available. The capacity of CD is 700MB while a DVD holds data up to 4.7GB.
If you need to burn a disc image like an ISO file (.iso) and you want to install a disc burning software, try DAEMON Tools Lite. It supports Windows 2000 Service Pack 4, Windows 98, Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2008 and Windows Server 2008 R2.
This program allows you to mount disc images on your computer on a virtual drive. It also allows you to burn disc images on a blank CD or DVD. Supported image formats include .mdx, .ccd, .bwt, .vmdk, .mds, .isz, .nrg, .vdi, .mdf, .cdi, .vhd, .iso, .b5t, .tc, .cue (ape, bin, flac, wav), .img, .b6t, and .iscsi.
You can download and use DAEMON Tools Lite for free or buy a license. But if you only want to burn discs and not create virtual drives, you can try ImgBurn. It supports Windows 95, Windows 98, Windows Millennium, Windows NT4, Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server operating systems.
