NativeAddIn is giving an error message
Hi experts
Native AddIn is giving an error message box during MS Outlook startup.
Need a solution. Please help me to solve this.
Thanks in advance.
The error is:
Error:
Native Addin
OnConnection
Hi experts
Thanks in advance.
The error is:
Error:
Native Addin
OnConnection
I’m not sure if this is really an error of some kind or only a notice for the user to be informed. The information on that dialog box doesn’t mention anything about an error.
Try clicking on the OK button of the dialog box and see what happens. If you can’t really work after hitting on the OK button and Microsoft Office Outlook automatically cancels the loading of the application, you might probably added an add-in that is not functioning or is not compatible with that version of Microsoft Outlook.
You should check first the availability or compatibility of the add-in before installing it on the application.
Since this is the current state of Microsoft Office Outlook, try uninstalling the application from your machine. If it’s part of the Microsoft Office package, just remove only this feature from the whole package.
After its removal, check your computer for any possible errors. Use a disk utility application to check the system. Then after the disk check, install Microsoft Office Outlook again. This time, don’t install the add-in that caused the problem.
