NBA 2k13 error, can not start the game
I am getting the following error message when I attempt to start the game.
It was working well but when I installed new drivers for NVIDIA an error message appears.
Now I am confused how to remove this error?
What is the reason behind this issue?
I really need a proper solution.
Thanks for any help.
The dynamic library “rld.dll” failed to load. Please confirm that:
The file was copied over the same folder as the cracked executable The antivirus software is not false-detecting the file (in which case white-list the folder/file)
Answered By 5 points N/A #167565
Hello Reginald
Your game fails to start because you have copied the rld.dll into a different folder. You must copy the file into the installation folder of NBA 2K13.
Second of all, make sure that your antivirus allows access. Whatever antivirus you have, go to Settings (Permissions/Exceptions) and add the NBA 2K13 as an exception. Or you could just disable your antivirus while playing the game. Also disable the firewall to be sure.
I suggest you download and install the software that I provided you with, and it will fix your dll errors.
Get DLL-files Fixer
I hope you will find this information useful.
Randolph
