Nebula3 Application Error on Drakensang Online
I just purchased an ATI Radeon HD 7770 graphics card and right after the upgrade, I was prompted with the error below when I tried to log in to the Drakensang Online. I tried to upgrade everything including Java to no avail. And now I am thinking that Since the error started after changing my graphics card then maybe the issue started here. So I want to know if my graphics card is compatible or there is other issues that cause the error to appear. Any insights about this?
Nebula Application Error
D3D9RenderDevice:: SetupAdapter()has failed with ’D3DERR_NOTAVAILABLE’
Thread: GraphicsInterface Thread
OK
Answered By 590495 points N/A #114721
I think you have a good video card with AMD Radeon HD 7770 just to be used playing Drakensang Online. It seems you did not check the system requirements needed for Drakensang Online since according to several users, nobody made it available online until they pursue on asking about it. Actually, the game is not heavy on the requirements.
It can even be played on Intel Pentium 4 2.8 GHz. The required physical RAM is around 1 GB minimum for Microsoft Windows XP and higher for later operating systems. I’m not sure if the game is tied to a specific brand of graphics adapter because it only mentioned NVIDIA as its video card but I’m sure you can use any other graphics adapter as long as it has 256 MB video RAM.
Drakensang Online can be played on Windows XP Service Pack 3, Windows Vista, and Windows 7. Check if your video card has at least 256 MB video RAM because if it only has 128 MB or lesser then you cannot play the game because it is no longer supported. If your video card has 256 MB and more then there should be no problem.
Just try updating your graphics adapter’s driver by going to AMD Graphics Drivers and Software. See also AMD Graphics Driver Can’t Be Unpacked for other information on how you can update your video card.
