Nec Ip2at 12txd Headset
Hello, I am trying to connect a handset to the ip2at 12txd headset, but I can not find any connection to the handset. Is there an upgrade card for the handset itself that provides a connection? Can anyone help, since it makes no sense, if there is a button to turn the headset on and off, then there must be a physical connection?
