Hello dear experts,
I want to know if I can access my friend's computer remotely or connect my computer to his PC. I know the IP address that he's using and I also have an internet connection. What are the steps to access his computer remotely? Please don’t disappoint me. Help me to do so.
kristin
Need to access computer remotely through internet
Hello dear asker,
If you are asking can you connect to another computer by their IP address the answer is yes. For example if you want to see if another computer is open to drive mapping, you need to do some steps.
First of all go to Start menu and hit Run. Type cmd in the run command window and press Enter. This will open a black (DOS) window for you.
Then type in the black window:
Net view \ipaddress of the computer you want to look at.
Get this program and install Perl to really see what the other computer has loaded if a web server you can see what you can connect to. There is also another way. Do you have steady IP? If so then this link will be working for you: Symantec — PCAnywhere. You can get the trial version for 30 days here. You also can buy the full version with only $40 to use this permanently.
Hope you get your problem solved.
It's easy to check the IP of your friend but what you want to do with your friend's computer. There are so many tasks you can do can even modify it by IP.
You can turn your friend PC off, and so many tasks what you want to do.
louis
Dear Russel Nesson,Â
Just a simple way you can access a computer remotely by using some software’s. The name of one popular software is TeamViewerThe Process of using team viewer are given below:
1st download and install two computers. Then software and you will get an auto generated id and set a password as you want. Use your partner ID and click on remote control finally connect to partner.
Thanks and Regards,
Louis
Hello Russel,
There are many ways to connect remotely to a friend’s computer. There is a lot software available on the market and on the internet for this.
I suggest you use Team Viewer for this. This software is very popular among remote control technology. You can control the entire activity of another computer with this software. You will need an ID and a Password to connect with another computer. You can download it from this link.
https://www.teamviewer.com/en/download/windows/
