Is there a way to remove the Accuweather application in my Samsung wave phone? I'm having trouble using this app for a while now and I've been browsing all day on how to uninstall it. Do I need to download an app to do that? How to uninstall it? I need my Accuweather remove Samsung wave phone. Please help.
Need accuweather remove samsung wave
Your problem appears to be common with Samsung products and Accuweather. A simple removal of the app is not enough, as you will need to access the Android OS root folder. You will first have to root your device, which will make all warranties void by doing such. Once the phone is rooted, you can download an app that will allow you access the root folder for apps, in which you will then locate the Accuweather app and manually delete it from your device. You can find out more tips on rooting your phone for this purpose at https://forums.androidcentral.com/samsung-galaxy-s-ii/115755-uninstall-accuweather-com.html.
