Need Acer home theatre driver
I am looking for Acer home theater driver.
I am using Acer home theater, and it is not working properly after formatting my system.
Please resolve my issue.
How can install the drivers in Windows XP?
Thanks Experts.
Regards.
Best Answer by Sharath Reddy
Answered By 0 points N/A #197305
Go through the Acer support center link provide your device model and download the audio driver that is included with Dolby digital home theater system. Click the link:
Answered By 590495 points N/A #139498
You only mentioned that you are using an Acer Home Theater but you forgot to indicate the model number of your device. But anyway, since we are guessing here, here is a driver for Acer Aspire X3200 series with part number AspireX3200 Aspire X3200.
If your computer is different from this one, don’t attempt on downloading and or installing it on your system to avoid further system damage.
Before downloading the driver, be sure that your model is Aspire X3200 and check the operating system that it is running on for the right version of the driver. Browse the driver database then find the Acer driver.
After that, select and download Aspire X3200 driver and then install it on your system.
Restart your machine afterwards then see if it works.
To download Aspire X3200 driver.
