Clark Orcus
20 points
Posted on - 03/08/2012
I need some necessary fonts added to my MS Word 2007 but I do not know how to do it. I am having lots of trouble since I have to work with those fonts. I will be glad if someone help me solve this problem of mine quickly. Please do help me.
Clark Orcus
Need to add new fonts in MS Office
hey Clark!
If you want to add new font to MS Word you have to follow these steps:
1. Click on Start>control panel>Fonts.
If you are not able to find fonts on control panel, you must switch to Classic view.
2. Open the FONTS folder and you will able to see all the fonts installed on you PC/Laptop.
3. Now you have to go to "file" and click the "Install New Fonts".
4. A new Dialog box will appear. Select the folder where you have the fonts that you want to install on MS word.
5. Click the font you want to add to MS word.
6. Click OK and you are done.
7. Now open MS Word, you see your desired fonts in Fonts list of MS Word
Thanks
Hi
Clark Orcus
You do not have to make it difficult to do. The easiest way to add new font is described below.
Just go to my computer. Then open the c drive and go to the windows folder and select the fonts folder. Now copy the font you want to use. You can copy just one font or more than that. In c/windows/fonts, paste the font you want to use. Now start the office document and scroll through the font tab and there you will find the font you just have installed.
Is not it easier than you thought!
Hope this helps
Thank you,  Tunacao_Caaron1 for your step by step guide. I followed your steps, I just selected the font I want to install and done. I can use my new fonts in Ms Word. Thanks.
