My problem is to change the URLs that are in snippet . When I run the converter trying to replace the URL on the snippet , nothing happen.It shows "not found" message. The converter is okay and is installed successfully . So, I need to know how to replace URLs on Adobe script tool .
Need Adobe script tool to replace URLs.
You can see the attachment image, in which you will see find option, which helps you to replace such as URLs, text. Find option search multiple files on the current time. In the find panel option, select URL from the second pop-up menu, enter the URL what you want to search, then Enter the replacement URL which you want to be replace. Word or number matches conditionally during the search.
Hello Hamillton,
If you want to replace URLs on Adobe try using 'Link Converter.jsx" script in the Script Explorer that are provided in the instructions from Weekly Skills & Drills by Kevin Siegel at Iconlogic. You can easily find these instructions on the web, they are updated all the time. I believe that the convection will work without any problems.
Good Luck
Moses V Patterson
