Need advanced rar repair please
Hello, I need to repair my rar files ,please advise about a secure website to download advanced rar repair. Thank you in advance
Hello.
Solution to your problems is very simple.
There are many websites which offer several softwares to repair rar files.
They are easy to download and installation does not take much time.
Just follow the steps given by the software after installing.
Click on the below links to download the repair software’s.
http://www.repairrar.net/corrupt.html
https://www.datanumen.com/rar-repair/
Hi Dear,
WinRAR is a software which compresses your files and implement security on it.
WinRAR provides also Repair service.
Just open WinRAR Click on tools or press ALT+R Key then a repair dialog box will open click on browse and select your file.
When you select you corrupted or infected file 2 Radio buttons will be shown under the file name.
1. Treat the corrupted achieve as rar.
2. Treat the corrupted archive as zip.
You have to select which type of files you are going to recover. If it is rar file then choose rar option. If you are using Zip file then choose zip option.
This will help you but Not 100% assure.
You should have to use any software if it fails.
That software can be downloaded from here.
http://www.repairrar.net/download/repairrar.exe
Thanks
