A few days ago I encountered an issue with my motherboard.
A friend of mine asked me to tell him exactly the components of my PC but I did not knew them.
So he told me about a software, called Aida 64.
I searched online, but I could not find a good version.
So I ask you people, if you can provide me with the Aida64 Extreme Edition full download location, and if it is possible, some instructions on how to use the software.
Need Aida 64 Extreme Edition full download location
There's no better version except those which can be found in the Official Aida 64 website.
Beware of downloading installers outside the official Aida 64 server because you might be a victim of software counterfeiting, and it may put risk to your machine.
There are two options of Aida 64 download – Extreme and Business. Install the Extreme version for home use. Both come in a 30- day trial. For stable Aida Extreme version, please click here. Business version, please click here.
To install, Run the installer as admin, accept terms and licenses then finish setup by clicking Next.
Hi Katherine,
The Aida 64 Extreme edition can be downloaded from the Softpedia website
The software can be used for following factors:
1) It is compatible with 32 and 64 bit Microsoft Windows operating system
2) It implements set of 64 bit benchmark to measure data processing, mathematical calculations
3) It provides with stress test where systems temperature and voltage readings can be monitored
4) It supports 250 sensor devices to measure fan speeds, temperature
5) An alarm is provided to detect the over heating, over voltage, fan cooling failure
6) It consists of hardware detection capabilities to provide CRT and LCD display status of the system
7) It provides information about installed programs, software licenses, security applications
