Need Alienware Alpha Overclocking Issues solved
80 points
Posted on - 02/15/2015
I read somewhere that the core clock of the Alienware Alpha can be boosted by around 135MHZ over the maximum 1097MHz. A laptop GTX 860 M memory speed reduction is also reversible compared to the desktop counterpart. You can wrap it from 5GBPS to 6GBPS. If I opt for one, what performance and overclocking should I expect? Since the GPU is not upgradable, what are the benefits of upgrading the memory or the CPU if I only want to use it for gaming?Â
