Recipe Manager is a recipe software organizer or recipe software management database that allows you to store all your cooking recipes online. But I need android recipe book import into csv files. What is the best software or system to import recipe book into csv files?
Need android recipe book import into csv files
I guess “My Recipes – cookbook Version 2.0” is your require Application. You can synchronize your cookbook with Mobile or Tablets. And yes this software can import recipe book into CSV files too. With the help of this app you can create your own recipes with images. A good app for cooking lovers.
Hi David,
Here are a bunch of android apps from which you can mange you recipes. All these apps are on Google Play store so you need not worry as these are fully trustable. You can have a look at the apps from the links given below.
Google Play link 1
Google Play link 2
Hope this helped you!
Drianna allen
