Need an anonymous quickie phone app
Hey man!
have you used anonymous quickie phone app ever? I need some of them on my galaxy ace, will you please give some good link for downloading it?
Best Answer by Luker Malcom
Answered By 10 points N/A #131909
Hello Coshaun,
I am going to write down the solution of your quickie phone app for android. You have two options.
1st Option:
·  Click on the mentioned link:
·  It opens the website which having this free application. You can download it install it free on your mobile.
Harthy Opera
Answered By 5 points N/A #131910
There is an application for android called “quickie notes”. It is a nice and neat to-do app that also features functionality not commonly found on your phone’s default note pad. So if you are a busy bee, then this software will be very helpful. This is a free downloadable app for all, so if you want to have this, just go to your Google play store and search for quickie notes. It will only occupy 419kb of your pone memory so that is also one good thing about it.
