Need the app uninstall research
I have android installed device. I want to see the message after I click on Uninstall and before the Package Uninstaller is called. How can i see the activity before my app is uninstalled
 you have to do the follow some steps to uninstall an app on your Android. First you Navigate to your devices settings and press the icon to launch in the setting application. Now  in the settings menu, you will see a listing of all the settings that you want to  change. Select the "Applications" listing to continue with the uninstalling process.
After pressing the Applications menu from Settings, Here you will find a list of 5 choices. Now you have to press the "Manage applications" icon that will allow you to manage and remove your installed apps.
Once in the Manage applications sub menu, you will see a list of your installed applications. On the top of the screen, Now you will see four icons; Downloaded, which will list all the apps that you downloaded and installed; Running, which shows all currently running apps; All, that lists all the apps installed on your device; and On SD Card that lists any apps that you have installed on your SD card.
Press on the app listed that you want to delete. Screen will appear that will give some details about the app, including how much storage the app consumes, how much of information is stored in your cache file and any default launch settings.
Once you are certain that you have selected the correct app and that you want to delete it from your phone, press the "Uninstall" button. This will begin to delete the app from your device. Once finished deleting, your screen will show that the app has been deleted.
