I want to free download application for USB drive which detect and fix its problem I need application like USB registry fix cleanup if any body have working URL.
Please give me and solve my problem.
Need application for usb registry fix cleanup
Hello Alissarachel,
What you are looking for is a software that detects and fixes issues with your USB driver.
If you are using windows then you get this facility automatically.
Windows 7 has its own feature to detect and fix general USB problems.
If you are looking for a recovery tool for your USB drive then I would suggest to check out the following application.
http://www.piriform.com/recuva
Hope it helps.
If you want to solved your registry problem and cleanup your computer you can use portable wise registry cleaner.
The interface is very easy to use for novice users and pros alike.
Just go to the site:https://portableapps.com/
