Hi ,
I am using HTML 5 to create an autorun HTML setup. But I don’t know from where to start. Do you guys have autorun html setup template so that I can go through it and create my own?
I will be really grateful.
Need autorun html setup template for my task
There are quite a few Autorun html setup template available on the internet, Which you can find easily, Now, I have couple of links, Which surely will be able to help you out, These template are easy to make, Create your own scrapbook, Fully customized, Now here are the links,
http://softwaretopic.informer.com/autorun-html-setup-template/
http://www.filebuzz.com/findsoftware/Auto_Run_Cd_Html_Template/1.html
Thanks
