Hi expert, To watch blueray videos I am using Kmplayer 3.5.
I need awesome Kmplayer live skins.
Skins should want in black color.
Please send the download links for Vista.
And send some helping tutorial explanations for reducing the RAM buffer.
Need awesome Kmplayer live skins
Hi John,
You can get numerous skins right from their official website. Here is the link.
As for the reducing RAM buffer there isn't exactly a way for something like that. But if you want to increase your PC performance you can always turn off your background programs you aren't currently using.
Hi John Valentine.
I will give you the name of software you can download, try to search KPM media it a name of skin software for your Kmplayer its compatible with all operating systems.
Now you will be enjoying watching blueray videos with your awesome skin that you downloaded.
Hope I helped you.
