Need to backup iPhone SMS to Windows Computer
Hello!
I want to transfer or backup my iPhone SMS to my PC. Is there an application that would allow me to do that? As much as possible, I don't want to spend much on applications.
Thanks!
Hello!
Thanks!
Hello Jdivinegrace,
You might already be familiar with backing up your Iphone's data on a computer through iTunes, now i will show you how to backup your messages to a computer through iTunes, please follow the instructions:
– Backup your data as usual via iTunes.
– Once you have done that, C:Documents and SettingsyourcomputernameApplication Data
– Now in that folder search for a file named .mdbackup or .mddata.
– Open it via Notepad and you will find your messages in it.
