Need a basic idea of xml publisher work for open office.
What is xml publisher? How does xml publisher work in open office? Is it only used to format a report or article? Is it possible to create an email alert for xml publisher for open office?
It’s a template-based publishing solution which comes with the Oracle E-business Suite. It combines common word processing tools with E- business Suite reporting. It can merge the custom templates with the data extracts to output html, excel, PDF or text for use with EDF and EDI transmission.
Unfortunately Open Office is not yet supported with XML Publisher.
See https://community.oracle.com/thread/874044
XML Publisher is a template-based publishing solution. It’s the new reporting technology. Earlier it was developed to solve the reporting problems for Oracle Applications only. Now it is known by the Oracle BI publisher.
It simply takes an XML data file as input and then merges it into a standard template and produces the necessary output in Word/PDF/Excel/email/EDI etc. It can be used with OpenOffice (OO) For that you need can install the Oracle BI extension for OO.
Regards.
Laz Zebbena
