Need the best auto install maker.
Hello, I am using Smart Install Maker. But I am in need of more reliable in installation. Can you suggest me that I can save more time? Thanks….
Harlow Elsitebrown?
concerning your question , use the instructions below.
Please download “Smart Install maker 5.04”.
Download it is www. softpedia.com
After download the software you can follow the screenshot on the same website.
To use this software you will need the following requirement:
Pentium CPU or higher/ 64 MB RAM/256-color display/2.64 MB free disk space
It is an easy to use software installer for your Windows based programs. The Actual Installer is the ideal choice! This professional tool allows you to create reliable installation programs, ready for distribution, with ease. Now you can just forget about time consuming scripting and learning manually. All you need to do is to fill out the necessary forms and then attach the program's files.
Here is the free download link for the Easy Install Maker
Notifications
