Need best registry fix tool for Windows XP in Market
Hello Techyv users,
There is always some problem in my windows XP registry entries, Which I have to manually edit. For this reason I require best registry fix tool for my PC to automatically fix the errors in registry whenever they occurs.
Answered By 60 points N/A #166067
Hello Jak,
Welcome to the forum.
I will not miss the opportunity to help you with a great application to fix PC errors. In my last 12 years of IT experience I have come across so many software  in the same category but there are two such software who are best.
1. Ccleaner- Link for this : http://www.piriform.com/ccleaner
2.Tune Up Utilities – Link for this : https://www.avg.com/en-us/tuneup-utilities
Hope this tools will help you to fix your issues related to registry.
Thank You.
Answered By 590495 points N/A #328449
If you keep having a problem with the registry, you can use either PC Tools Performance Toolkit or CCleaner since both applications feature a registry cleaner. This will allow you to fix invalid entries in the registry and remove entries left by uninstalled programs. Download the free version of CCleaner and install. Once installed, start CCleaner then select “Registry” on the left pane.
Make sure all boxes are checked then click “Scan for Issues.” When scan is complete, click “Fix selected Issues.” When you are prompted to back up the registry, click “Yes.” Select a folder then click “Save.” After this, click “Fix All Selected Issues.”
